Go to Post the hardest task this year is the same as every other year: getting the engineers out of the crate so you can close it up and the FedEx guy can haul it away! - KenWittlief [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 22-01-2010, 21:57
rjbman's Avatar
rjbman rjbman is offline
Animator Dominator
FRC #2081
Team Role: Animator
rjbman is an unknown quantity at this point
How to remove partial lines in Ink'n'Paint
I'm using Ink and Paint as the material for part of our team's animation, but when I try to render it I get some extra lines I don't want to be in there. Is there some way to remove them? I attached an example. I mean the lines where its just part of the ship, but not on any intentional borders. Any help?
Name:	ship wrong.jpg
Unread 23-01-2010, 11:23
rjbman's Avatar
Animator Dominator
FRC #2081
Team Role: Animator
Re: How to remove partial lines in Ink'n'Paint
I made a new ship... the problem is gone.
Unread 23-01-2010, 12:10
MadeAtMidnight's Avatar
MadeAtMidnight MadeAtMidnight is offline
AKA: Carrie Asner
FRC #1625 (Winnovation)
Rookie Year: 2007
MadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud ofMadeAtMidnight has much to be proud of
I think I figured out how you can get rid of the lines (in case it happens again). Under the Ink and Paint controls >> Ink Controls >> SmGroup and turn that off, it gets rid of the lines.
Hope this helps.
Carrie
League of Mothers founding member
"There are two ways to spread light; to be the candle, or the mirror that reflects it."
Edith Wharton
Unread 14-02-2010, 01:02
3DElizabeth's Avatar
3DElizabeth 3DElizabeth is offline
Animation Mentor
AKA: Elizabeth Barndollar
FRC #0342 (The Burning Magnetos)
3DElizabeth is on a distinguished road
I'd also recommend checking your smoothing groups on the object. Changing the smoothing will make like appear or not appear in objects. Smoothing groups can be found under the modify panel one polygons are chosen.
Good luck.
To Remove or not to Remove..that is now the Question? ShadowNinja General Forum 16 04-01-2009 18:29
CD-Events gets a (partial) face-lift Brandon Martus Announcements 4 30-04-2007 16:05
How to remove pulley from CIM motor de_ Motors 14 01-02-2006 20:49
Partial Nick Mac Off-Season Events 11 17-06-2003 22:50
team 857 partial 2003 robot ajlapp Robot Showcase 14 27-01-2003 22:30
