Go to Post All this community stuff is actually pretty fun! :) - JBotAlan [more]
Unread 31-01-2010, 01:23
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
Post Re: Problems Imaging the cRIO
Originally Posted by rhoads2234 View Post
we don't get voltage readings on the Driver Station.
Any ideas?
To receive the battery voltage readings, you need to power up the Analog Breakout attached to one of the cRio modules. + and - from the Analog Breakout go to the Power distribution board and use a 20 amps breaker.
THere is no additional code required to get the battery power readings.
~ Priyank
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
cRIO Imaging Error Scip Programming 1 20-01-2010 21:48
cRIO imaging alex42 FRC Control System 3 16-01-2010 20:05
cRIO imaging tool dnrobotics11 Programming 4 14-01-2010 23:32
Problem with cRIO Imaging Tool Doc Wu FRC Control System 7 15-12-2009 19:47
FRC cRIO Imaging Tool furiousgeorge Programming 1 06-02-2009 09:52
