Go to Post Who has time for boredom? - Dr Theta [more]
Unread 23-01-2010, 14:51
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Vision Code crashing
I think I ran across this before here on CD, but I couldn't find the thread once this happened.
We are using the CircleTrackerDemo project with Java to drive our robot. Apart from changing the drivetrain settings, it is unmodified.
At first it worked perfectly, but after a small robot demolition derby (people need to think, but they prefer not to,) it no longer works.
The code appears to work as long as the trigger (which activates the tracking) is pressed. There appears to be a separate (program, not CD) thread that runs the vision code. However, for unknown reasons, it is crashing now.
We also had communications issues (which developed overnight,) so we checked the dip switches and re-imaged the cRio. Not, communication appears fine, but the camera still only functions when the joystick trigger is pressed.
Here's the last output from NetBeans:
Code:
[cRIO] * Loading StartupDlls: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2010 FRC, Dec 30 2009, 15:22:08
[cRIO]
[cRIO] [OTA Server] Starting...
[cRIO]
[cRIO] [OTA Command Server] In serverSocketListener()
[cRIO]
[cRIO] [OTA Redirector] In serverSocketListener()
[cRIO]
[cRIO] task 0x215a590 (t2) deleted: errno=0 (0) status=0 (0)
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 8.6.1f2
[cRIO]
[cRIO] NI-VISA Server 4.5 started successfully.
[cRIO] task 0xe62058 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
[cRIO] [OTA Server] Restarting Java VM
[cRIO]
[cRIO] Bootstrap suite loaded
[cRIO] In Startup
[cRIO] Looking for implementation class com.sun.squawk.platform.posix.vxworks.natives.SelectImpl
[cRIO] FPGA Hardware GUID: 0xad9a5591cc64e4df756d77d1b57a549e
[cRIO] FPGA Software GUID: 0xad9a5591cc64e4df756d77d1b57a549e
[cRIO] IterativeRobot Constructor Start
[cRIO] IterativeRobot Constructor Finish
[cRIO] IterativeRobot startCompetition() Start
[cRIO] task 0x2158710 (FRC_cameraTask) deleted: errno=0 (0) status=0 (0)
[cRIO] Default RobotIterativeBase::DisabledInit() method running
[cRIO] Disabled_Init() completed
Does anyone have an idea what's happening? Thank you for any help.
Nonexistent Vision Code linkhyrule5 NI LabVIEW 6 12-01-2010 00:48
Not Really Working Vision Code linkhyrule5 NI LabVIEW 0 07-01-2010 18:45
DS crashing ThisAintJeff FRC Control System 3 14-12-2009 14:48
Max Crashing SGK 3D Animation and Competition 11 02-02-2003 20:51
