ok, deal is we build and deploy the code in labview, and it deploys succesfully, but then when we go to the driver... it has communication, but says no code! help?
Re: Driver station say no code!
So, you deploy the code to the cRio, and the driver station says it has no code.
Have you any code on the driver station? Did I misunderstand something here? (I often do) |
A common sequence seems to be logging into developer account, running code, then logging out of the developer account to run the DS.The problem is that when you log out of the developer tools, the code on the cRIO is aborted as well - at least this is true for LabVIEW.
The solution is to stay logged into the developer account and launch the DS from the Start menu. Greg McKaskle |
| Robot code isn't loading onto driver station | TigerDrive2391 | Programming | 2 | 24-01-2010 15:32 |
| Deploying code from the 2010 driver station - Netbeans | joshholat | Control System | 5 | 23-01-2010 15:01 |
| Driver station not detecting robot code | captainking | NI LabVIEW | 9 | 21-01-2010 10:39 |
| 2010 Driver Station Netbook Driver Account and Java | joshholat | FRC Control System | 2 | 10-01-2010 15:04 |
| Save code to Driver Station | Comatose | Programming | 5 | 17-01-2009 18:48 |
