Go to Post Chairman's Award is not about building the robot. Every team builds a robot. - Retired Starman [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 23-01-2010, 15:51
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Position Control using potentiometer?
In BDC-COMM, I can set the control mode of the jaguar to position using a potentiometer.
The little text box that displays the position updates as I move the shaft, but when I try to move the shaft to a set-point, the shaft always turns away from it.
So, when I tried reversing the sign on the PID constants to make it go the other direction, it would turn past the point and never try to come back to the set point.
Also, I tried using the soft-limit feature on the Jag, but the jag happily goes past the limit without stopping.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Using the cRIO to control custom lights hal_2498 FRC Control System 14 10-04-2009 07:55
Using a pot to control speed SL8 NI LabVIEW 13 18-02-2009 17:02
Potentiometer arm control Hazmatt Programming 15 01-04-2008 21:27
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
Using a switch to control a PWM Max Lobovsky Programming 11 25-02-2004 17:20
