Go to Post [the last period is] a free for all, both goals are turned on, and any robot can go anywhere on the field and score in any goal (although I would recommend scoring in the correct goal, not your opponents :D ) - Ryan Foley [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 23-01-2010, 15:57
Dylan5019 Dylan5019 is offline
FRC #2779
Dylan5019 is an unknown quantity at this point
Mecanum Wheel Setup Help
We decided to go with a mecanum wheel drive system this year. However, when we got everything set up with the Holonomic VI we were able to spin and strafe but not actually move forwards and backwards.
Right now we are converting our X and Y axis to radians with ATAN2 then to degrees and using that for direction, and getting our magnitude by taking sqrt(X^2+Y^2). We wired a straight 0 to rotation. We hoped to see simple translational motion working. It's also possible that the orientation of the mecanum wheels is incorrect. whe have them set so that the rollers in the front are to the left and the rollers in the back are to the right. We tried the "X" pattern and the results were worse then curently
IDK if this is a mecanical or programming error, but hopefully someone will know. If you have experience with mecanum set up you can contact us by text messaging 918-406-8420. Thank You!
Mecanum Wheel Considerations abross General Forum 20 23-01-2010 19:34
HELP: Mecanum wheel Inside spacers Sam2197 Technical Discussion 2 19-01-2010 23:36
Mecanum wheel size Mr. A Technical Discussion 7 18-01-2010 08:58
pic: New mecanum wheel? scottydoh Extra Discussion 5 16-01-2010 21:29
pic: Micro Mecanum wheel Tytus Gerrish Extra Discussion 6 12-05-2005 23:20
