Go to Post The greatest lesson we can teach our kids is how to win. - AdamHeard [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 23-01-2010, 16:43
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
Compressor Code causes No Robot Code Error
I've just tried to add the Compressor class code to my C++ Iterative Robot code and when I load it to the robot it causes a no robot code error. Has anyone else run into this problem and do you have a solution on how you fixed it.
The code I used was:
Code:
public:
 * Constructor for this "IterativeRobotDemo" Class.
 * Create an instance of a RobotDrive with left and right motors plugged into PWM
 * ports 0 and 1 on the first digital module.
	IterativeDemo(void)	{
		cout << "IterativeDemo Constructor Started\n";
		// Create a robot using standard right/left robot drive on PWMS 1, 2, 3, and #4
		myRobot = new RobotDrive(1, 3, 2, 4);
		// Define joysticks being used at USB port #1 and USB port #2 on the Drivers Station
		rightStick = new Joystick(2);
		leftStick = new Joystick(1);
		// Acquire the Driver Station object
		ds = DriverStation::GetInstance();
		dsLCD = DriverStationLCD::GetInstance();
		// Counters to record the number of loops completed in autonomous and teleop modes
		auto_periodic_loops = 0;
		disabled_periodic_loops = 0;
		tele_periodic_loops = 0;
		//Compressor Instance
		Compressor *cpressor = new Compressor(1,1);	//Input DIO Port 1, Relay 1
		cpressor->Start();	//Start compressor
I have the compressor Spike wired to Relay 1 and the Pressure Switch wired to Digital Input 1. Would I get a no robot code error if something wasn't physically connected right? The example in the User Guide said to put it in the constructor of the robot and that's the only place I need it, which I have done.
The robot works fine without the compressor code, its just when I uncomments the line above.
Any ideas? Help.
User code won't download/run-possible causes? nathanww C/C++ 3 21-01-2009 11:00
Code error causing robot to go into programming mode. MJD Programming 14 30-10-2007 14:21
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Compressor Code gacp Programming 2 19-02-2005 16:18
