Go to Post Spelling mistakes make me sad...Almost as sad as not being able to go to Atlanta this year.. Almost. - Elgin Clock [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 23-01-2010, 19:35
WildBill's Avatar
WildBill WildBill is offline
FRC #2845 (O'Botics)
Team Role: Coach
WildBill is an unknown quantity at this point
Arrow Octagon
Our team was considering a modified octagon design. We have not had any luck searching for pre-made 135 degree brackets. We do not know all of the suppliers - mainly look at AndyMark and google search. If there is any senior teams that know a possible supplier we would be happy to receive advice.
Unread 23-01-2010, 19:59
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Re: Octagon
80-20 has a 6 hole 45 degree that should work. But it may be faster/cheaper to cut & drill aluminum plate.
Or cut the kit chasis down in size for the 'rectangles', and 1x1 aluminum square tube (available at Lowes & Home Depot) will fit inside the kit 'C' channel for the angles.
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Octagon
Are you looking to use the Kit chassis rails?
I think the Corner Connect's in the kits can turn at such an angle, look at the omni kit chassis, it looks like they are turning at 45 degrees there. You could probably get it to work. You could always make a plate of aluminum to turn the corner, and put it on the top and bottom, attached with two bolts to each piece. You might need to face some of the angled pieces with the C facing out instead of in, to get the Corner Connects to work.
Kettering Motorsports
Unread 23-01-2010, 22:09
NickE's Avatar
NickE NickE is offline
_
FRC #0254 (The Cheesy Poofs)
NickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond reputeNickE has a reputation beyond repute
Re: Octagon
http://www.8020.net/Quick-Frame-13.asp
Unread 25-01-2010, 10:50
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Octagon
The set your own angle brackets here might work out: http://www.mcmaster.com/#catalog/116/2991/=5j274g
Unread 25-01-2010, 20:13
WildBill's Avatar
Team Role: Coach
Re: Octagon
Thanks for the suggestions, we will take a look into them.
