Go to Post If this photo doesn't tell us why a photographer is important to a team, I don't know what will. - JaneYoung [more]
Unread 23-01-2010, 20:35
dungeonmonkey dungeonmonkey is offline
FRC #2458
dungeonmonkey is an unknown quantity at this point
KOP laptop driver interface
i noticed that when you load up the driver user account that the files loaded are labview files. in this case, i should be able to move the user interface around and change some functions if i can just find those files. does anyone know where i can find it?
Unread 23-01-2010, 20:48
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: KOP laptop driver interface
The bottom.. third-ish is the Driver Station portion. You cannot change that, that would be illegal.
The top two-thirds-ish, the part with the camera and the I reads, is editable. You can use LabVIEW to create a Dashboard project, and build it. We made ours bright yellow with purple boxes for the different sub systems, all yellow text on the purple boxes, and our logo. If you use LabVIEW, you can create a .ctl file with a cluster filled with all of the data that you need to pass (preferably in sub-clusters by sub-systems, and further subed as necessary to make it nice and neat) and copy it to your robot and dashboard projects. Then, once you swap the default controls and a few constants for them, you will be ready to go.
Kettering Motorsports
Driver Interface ajdecker1022 Java 15 18-01-2010 22:40
Driver Station to Dashboard Laptop connection slavik262 FRC Control System 4 12-01-2010 00:37
cRIO/Driver Station output to laptop smcmahon FRC Control System 3 14-12-2008 13:51
Driver interface Wayne Doenges Control System 7 16-02-2005 16:38
