Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Unread 23-01-2010, 23:11
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
Rookie Year: 2007
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
[FTC]: Rhode Rage Teaser
http://www.vimeo.com/8940859
See you in Delaware
Unread 24-01-2010, 23:39
ejak0 ejak0 is offline
FTC #3595
ejak0 is an unknown quantity at this point
Re: [FTC]: Rhode Rage Teaser
Nice work. It shoots very fast! It looked like some balls were falling out the bottom though (problem?).
Anyways, good luck!
FTC121 Rhode Rage Teaser BradMello Robot Showcase 2 24-01-2010 00:34
[FTC]: 121 Rhode Rage Pics and Videos Rick FIRST Tech Challenge 16 11-02-2009 17:21
[FTC]: Rhode Rage (FTC 121) is in need of a motor encoder wire Rick FIRST Tech Challenge 2 02-02-2009 01:56
[FTC]: Connecticut, Massachusetts, and Rhode Island - Regional Pictures Overyourhead FIRST Tech Challenge 2 09-03-2008 11:42
pic: FTC Team 655 - Rhode Rage Rick Extra Discussion 0 27-02-2008 20:57
