Go to Post Maybe the lesson the internet is trying to teach us is to "Think before you post, the machine is watching and never forgets..." - IKE [more]
Unread 24-01-2010, 02:11
Dylan5019 Dylan5019 is offline
FRC #2779
Dylan5019 is an unknown quantity at this point
Finding the Camera; IO Card firmware
I have a couple of questions that somebody probably can answer.
I'm attempting to get the camera set up and working, but I can't find it! My network is working with the classmate and dev pc both plugged into the router, which is wireless to the adapter & cRIO.
The way I understand the docs, resetting (i.e. hold the button until blinking) on the camera should reset its IP to a default 192.168.0.90. So I plugged it directly into the PC with the orange crossover cable, and changed my pc IP address to 192.168.0.01. However, I still couldn't ping 192.168.0.90. Any ideas would be appreciated, though I'll work on this a little more when I have some time to mess around.
Second question: The docs on programming the PSoC have me baffled on this sentence (Control System Ch.2 section 11): "browse to where you saved FRC_IO.v1.hex, and select the FRC_IO.v2.hex file." I don't know what the deal is, but I couldn't find ANYTHING about these imaginary files ANYWHERE. If anyone could tell me WHAT and WHERE they are, it would be appreciated
Thanks a lot for any help! -2779.
Unread 24-01-2010, 08:27
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Finding the Camera; IO Card firmware
The hex file is at: All Users/Documents/FRC_IO.v2.hex
Do you have the Driver Station Update installed?
There is an issue with the PSoC sw that may require reinstallation.
How are the camera status lights?
Possibly a conflict with multiple PC network cards.
Unread 25-01-2010, 20:30
FRC #2779
Thanks for the location of the PSoC firmware. However, I still can't find the camera. It's last year's axis camera, and I've tried resetting it many times. I simply connect it to my computer, disable the wireless connection, leaving only local area, and set IP to 192.168.0.6. Still haven't been able to ping the camera with this configuration. I tried setting my IP to 10.xx.xx.5 and trying to ping what might have been our old address, but to no avail.
Thanks for any help! -2779.
Unread 25-01-2010, 23:37
Just Itinerant
Did you reset the camera by pulling the power, then holding the reset button while plugging the power back in and continuing to hold until you got the orange light around the lens?
Do you have it mounted with the reset button up against the back, possibly being pressed constantly (had a team with that problem tonight).
The camera address shouldn't ever be changed from 192.168.0.90, but you never know. It sounds like you're doing all the right things with your PC.
Unread 27-01-2010, 21:02
FRC #2779
Thanks Mark, holding the reset button while plugging the camera in did the trick. We're completely up and running now.
Finding heading from camera. SL8 Programming 3 18-03-2008 21:29
Looking for Borrowed RS232 Camera Port Card from BAE Granite State Event psycho7 Regional Competitions 0 12-03-2006 13:55
Camera doesn't have firmware? no programming? GraphicArtDesig Programming 6 19-01-2006 20:10
Camera Range Finding russell Programming 9 31-01-2005 19:54
Does the new IFI Loader work with the old Firmware? gnormhurst Programming 2 17-01-2005 20:11
