4 motors
What would you have to do if you want 4 motor controllers, with one joystick?
Re: 4 motors
In Begin.vi do a
right-click-> Replace -> Robot Drive Paletteon "Drive - Open 2 Motors" to change it to "Drive - Open 4 Motors". Then specify the 4 PWMs to be used. Last edited by Mark McLeod : 24-01-2010 at 16:55. |
Re: 4 motors
Ok thanks a lot thats what I thought at first.
Re: 4 motors
The hardware option is to run 2 motor controllers via 1 PWM port and a PWM Y cable.
Re: 4 motors
We are also trying to change the 2010 Game Robot Project to drive with four motors & we have changed to Tank Drive. We have replaced the"Drive - Open 2 Motors" to "Drive - Open 4 Motors", but the robot is only driving with the same two wheels it drove with using the "Drive- Open 2 motor". Is there another step we need to complete because we have also changed to tank drive? I've attached a copy of our Begin VI. Can anyone advise? |
Re: 4 motors
Re: 4 motors
Thanks for the clarification! The wiring option will work. Thanks again
Re: 4 motors
The Y-cable PWM adapters come in the KOP. I have used them in two past years.
We had two motors on each gear box. We absolutely did not want them to do anything other than exactly the same thing. Using the Y-cable keeps the program simpler, saves a PWM output and prevents a code mistake from possibly running the motors in different directions. Whether you use the Y-cable depends on whether you need independent control of each motor, or whether they will be always working together. They can save you some coding and spare a PWM output at the expense of some flexibility. It won't save you a motor controller, because as stated perviously, you still need one for each motor. You can do this with either Victors or Jaguars. (Although I wouldn't mix them.) |
| Modifying motors for 2009 FRC motors | Ramiro_T | General Forum | 2 | 22-03-2009 01:33 |
| Motors, Motors, and More Motors | 1033missions | Motors | 1 | 09-02-2006 18:46 |
| Motors.. and more motors.. How many on your 2004 bot? | OneAngryDaisy | Motors | 33 | 23-02-2004 00:46 |
| Matching Drill Motors and Fischer-Price Motors | archiver | 2001 | 5 | 24-06-2002 00:51 |
| F.P. Motors & gearbox for $12.50 Window Motors $19.50 | archiver | 2001 | 1 | 23-06-2002 23:05 |
