Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 01-24-2010, 05:10 PM
FRC4ME FRC4ME is offline
FRC #0339
Rookie Year: 2007
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Java PWM getPosition() integer division bug?
After much troubleshooting trying to figure out why Servo.get() was returning 0.0 for any servo position other than 1.0, I noticed the following code in edu.wpi.first.wpilibj.PWM:
Code:
public double getPosition() {
    int value = getRaw();
    if (value < getMinNegativePwm()) {
        return 0.0;
    } else if (value > getMaxPositivePwm()) {
        return 1.0;
    } else {
        return (value - getMinNegativePwm()) / getFullRangeScaleFactor();
Notice the final return statement. value, getMinNegativePwm(), and getFullRangeScaleFactor() are all of type int. Would this not cause the integer division to truncate to 0 for any result less than 1? I checked the C++ version of the same function, and sure enough, the numerator and denominator of the fraction are cast to float before the division.
Go directly to queue. Do not pass pit.
Unread 01-25-2010, 03:21 AM
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Re: Java PWM getPosition() integer division bug?
Code:
        return 0.0;
        return 1.0;
    } else {
Please post a bug report at: http://firstforge.wpi.edu/sf/tracker...ilib_java_bugs
Thanks,
-Joe
Unread 01-28-2010, 11:16 PM
FRC #0339
Rookie Year: 2007
Thanks,
-Joe
I posted the bug report. Did I do everything correctly? Am I supposed to assign the bug to anyone in particular?
http://firstforge.wpi.edu/sf/go/artf...2647385673 24
Unread 01-29-2010, 12:56 AM
Rookie Year: 1997
Looks good to me. The right person isn't in the list. I'll make sure he hears about it.
Unread 03-03-2010, 02:31 PM
greekgod8591 greekgod8591 is offline
FRC #2577
greekgod8591 is an unknown quantity at this point
We've observed the same issue, hopefully first will put out a fix for this.
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 08-31-2009 03:55 PM
Using Integer variables programmr Programming 4 02-14-2009 05:26 PM
Displaying a 16 bit integer on PIC 16F877? Ian Curtis Programming 4 06-20-2008 03:42 PM
integer division ImmortalAres Programming 5 07-11-2005 09:19 PM
Integer Number powercat Programming 2 02-18-2003 11:26 AM
