Go to Post My lasting impression of 217 (for years now) has been based on how their robot looks, dynamically. It is poultry in motion. :) - Richard Wallace [more]
Unread 25-01-2010, 09:31
Kevka's Avatar
Kevka Kevka is offline
FRC #0975
Rookie Year: 2010
Kevka is an unknown quantity at this point
Touchsensors in the Bumpers legal?
Hi,
do you think it would be legal to install touch sensors in the bumpers?
And if so, which type would you use?
It would be hard to cover the whole wisth of a robot with microswitches.
Best Regards Kevin
Unread 25-01-2010, 10:03
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Touchsensors in the Bumpers legal?
The touch sensors cannot be incorporated into the bumper.
They have to be behind the bumper within the confines of the robot frame that supports the bumpers.
<R16> During normal operation no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as permitted by Rule <G30>.
There is a rule that allows us to push them out as far as the bumper front edge, but only for a maximum of 2 seconds.
Unread 25-01-2010, 10:20
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Kevka,
Within the bumpers is restricted as Mark has pointed out but it is legal to use proximity sensors within the robot perimeter. Teams have used optical and ultrasonic sensors in the past.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 25-01-2010, 10:28
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Also note that the bumpers and the frame behind it aren't allowed to be articulated. That's not to say you can't figure out a way for them to be firmly mounted yet still work as a sensor, but you need to think about what you want to measure.
Are you trying to measure impacts, or just touched vs not touched?
You could possibly use an IR sensor or a range finder near the bumper zone, or possibly through the bumpers with a carefully placed hole, though I doubt that it would be reliable through the bumper. (Also have to check if it is legal)
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 25-01-2010, 10:36
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
Don't run it through the bumpers if you don't absolutely have to (and then only with the Q&A's clearance, printed out and brought with you to the event so that the inspectors know that this was declared legal).
Q&A already shot down a gap in the bumper so the camera could view the field. I don't think they'd be too thrilled about a hole in the bumper for a sensor.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 25-01-2010, 11:32
Kevka's Avatar
FRC #0975
Rookie Year: 2010
The idea was to now, when the robot is crashing into things in order not to have it climb up walls (we had the problem during FTC that our robot would drive against a wall and then flip over).
I guess we will probably try distance sensors mounted a bit higher than the bumper. It will be harder to cover the whole width tough.
Thank you for everybody's fast reply.
Unread 25-01-2010, 11:44
Unsung FIRST Hero
Rookie Year: 1996
kevka,
Sensors mounted below the BUMPER ZONE but within the FRAME PERIMETER might work better to prevent the climbing you fear. However, I think the bumpers would prevent you from achieving the same response your FTC robot produced.
Al
WB9UVJ
www.wildstang.org
Unread 25-01-2010, 12:16
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If the application is to prevent driving up a wall and flipping over, consider using a 2- or 3-axis accelerometer as a tilt sensor. If the robot reaches a defined angle (and you aren't intentionally driving over the bump), have it stop driving (or even drive the other direction until the angle comes back down).
Unread 25-01-2010, 14:25
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
Ramming into a wall and flipping over is much less of a concern in FRC. Just make sure your CG is as low as possible.
2 sets of bumpers legal? ChuckDickerson General Forum 33 07-03-2009 12:37
bumpers for the front e1b Rules/Strategy 4 04-02-2009 21:45
Bending the Bumpers BeyondRamo General Forum 7 12-02-2008 18:39
The Bumpers latonya General Forum 6 07-02-2008 21:45
Question about the bumpers. Brad Voracek Technical Discussion 16 16-01-2007 07:28
