Go to Post Us, as adults, find ways to help the kids to make it happen. - aspiece [more]
Unread 25-01-2010, 12:04
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
pic: Robot Bump Analysis
Unread 25-01-2010, 12:12
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: pic: Robot Bump Analysis
Do you have a graph or another sort of worst/best case comparison graphic that would illustrate the difference in the path/orientation of the body of the robot when it is equipped with the pivoting wheels vs single wheels at the pivot points?
Maybe a graph of degrees of tilt vs the location of the CG (projected onto the floor) as it moves from one side of the bump to another?
That would really ice the cake for folks who want to make a comparison.
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 25-01-2010, 13:54
JesseK's Avatar
FRC #1885 (ILITE)
Blake
Folks who want to make a comparison should probably do their own bump analysis with their specific wheel base and then determine their clearances/weight distribution based upon their own chosen manipulators. It's pretty easy; you don't even need the exact detailed nut-and-bolt model of the drive train.
GitHub
Unread 25-01-2010, 15:29
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Rookie Year: 2007
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
What'd you make those models with? They're quite nifty.
Our team thought of another way using Inventor models of the bump and various robot designs and printing the bump on paper while the robot designs on transparencies. Not exactly rocket science, but our team members seemed to like the new perspective.
I wish I could find a nice way to do dimensionally correct physical simulations, but I can't really find any.
-Tanner
Unread 25-01-2010, 15:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
All you need is a 2D CAD sketch with proper tangent constraints. Then you can drag it around, change dimensions, and see if you'll hit.
Unread 26-01-2010, 14:16
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is offline
Coach
FRC #1086 (Blue Cheese)
Team Role: Teacher
Rookie Year: 2007
wilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond reputewilsonmw04 has a reputation beyond repute
Google Sketch Up would do this for you.
Currently: Coach FRC 1086/FTC 93
2006-2011 Coach FRC 2106/FTC 35
If you come to a FRC event to see a robot competition, you are missing the point.
paper: CG Migration of Robot Crossing Bump using Powerpoint IKE Extra Discussion 7 30-01-2010 22:55
pic: Two men in a bump joeweber Extra Discussion 3 18-01-2010 18:30
pic: Our design on the bump joeweber Extra Discussion 13 16-01-2010 23:14
pic: The IRI Bump Greg Marra Extra Discussion 2 26-07-2008 02:59
1501 Control System Basics and Analysis of a Bipedal Robot Chris_Elston Programming 1 25-12-2005 12:52
