Go to Post Am I the only one who thinks robots are the main attraction of a regional, and there isn't a need for more distraction? - Adam Richards [more]
Unread 25-01-2010, 13:01
CaptainMorton CaptainMorton is offline
FRC #0888
CaptainMorton is an unknown quantity at this point
USB Hub Doesnt want to be found
We were testing out a new input that we added to the I/O board and then noticed the stop button wasnt attached. We attached the stop button to the USB Hub and then promptly got the Blue Screen of Death.
Then we restarted the computer and tried again, without the stop button attached just in case, but the I/O board and the joysticks were not being seen. We plugged the I/O board directly into the Classmate and it showed that it was connected.
We restarted the computer and the problem continued.
Do you think that the USB Hub is beyond fixing or is there something else we should try to get it working again?
USB Hub Defective samcorp Kit & Additional Hardware 24 25-02-2010 13:15
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Plastic hub parts source found A_2 Kit & Additional Hardware 0 15-01-2005 11:23
USB to Serial -- Working Device Found! Eko Programming 10 23-02-2004 12:56
