Go to Post Remember, let function drive design, not the other way around. - Tom Bottiglieri [more]
Unread 25-01-2010, 19:13
Team3256's Avatar
Team3256 Team3256 is offline
FRC #3256
Team3256 is an unknown quantity at this point
Unhappy aahh! camera help anyone?
greetings from team 3256! programmer here, and I am on the verge of pulling my hair out. please help us and save my hair!
like other numerous threads I have read, we're having camera issues too. I'd like to think I've read through every thread about fixing the camera, but if I did, one would think it'd be fixed by now...-sigh- anyway, would anyone want to lend a helping hand to a rookie team?
here's some stats on what we have so far:
~running C++, the vision 2010 program.
~we've been able to configure ip address for the camera at 10.32.56.7, with FRC::FRC as username:assword
~we can get the camera to work by going through the address in an internet browser when it is hooked up to the computer/router, but when we get it set up in the cRIO, nothing.
~it's safe to assume every program we have is up-to-date (we did the whole driver station uninstall/reinstall thing-y, etc)
~we made sure to have the cross-over cable for the camera hooked up to Ethernet port 2 on the cRIO
~in another forum, I read about a "watch dog not being fed" for the first 12 or so seconds. we get nothing like that.
(~I'm kinda new to C++ too. I'm use to Robot C, not C++, so if you do any programming explanation, feel free to expand on some more complex ideas )
from my point of view, it should be working by now...but it's not...so something's wrong. any help?
Unread 25-01-2010, 19:31
Darkknight512 Darkknight512 is offline
Programmer/Electronics
FRC #3375 (North Stars)
Rookie Year: 2010
Darkknight512 is on a distinguished road
Re: aahh! camera help anyone?
I actually just got Team 3375's camera working, This is what I did.
1.Connect the camera to the computer with a crossover cable. Set Computers IP to 192.168.0.91 Subnet Mask to 225.225.225.0 Gateway Blank or 192.168.0.1 (Try both I forget)
2. Run the Axis camera utility thing.
3. Connect the camera back to port 2 with the crossover cable
3. Go into WindRiver and add this to the Initialization part of your program
Put this in your includes
#include "vxWorks.h"
#include "Vision/AxisCamera2010.h"
#include "PCVideoServer.h"
AxisCamera &camera = AxisCamera::getInstance();
camera.writeResolution(k640x480);
camera.writeBrightness(10);
Here is my whole file so you can't mess up putting the code in the right spot
#include "WPILib.h"
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
Joystick stick; // only joystick
public:
RobotDemo(void):
myRobot(1, 2), // these must be initialized in the same order
stick(1) // as they are declared above.
GetWatchdog().SetExpiration(0.1);
void Autonomous(void)
GetWatchdog().SetEnabled(false);
myRobot.Drive(0.5, 0.0); // drive forwards half speed
Wait(2.0); // for 2 seconds
myRobot.Drive(0.0, 0.0); // stop robot
* Runs the motors with arcade steering.
void OperatorControl(void)
GetWatchdog().SetEnabled(true);
while (IsOperatorControl())
GetWatchdog().Feed();
myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
Wait(0.005); // wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
4. Reboot the robot
If this doesn't work, make sure your Driver Station has a compass in the bottom right hand corner, if not then reinstall the Driver Station , and that your cRIO is flashed with v19
To do this, just use the Simple Robot template, The camera demonstration thing doesn't work for me.
Another note, the camera feed lags if you select the top window, select the bottom window and the feed is much more "real time"
Question to some of the other teams, My live feed has a light blue line down the middle about 2 pixels wide, I have no idea why its there, probably going to leave it if no one has any ideas because it could help with aiming I guess. Is it intentional?
Unread 25-01-2010, 19:40
ideasrule's Avatar
ideasrule ideasrule is offline
FRC #0610 (Coyotes)
ideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the roughideasrule is a jewel in the rough
We had to manually delete the entire driver station software from C:/Program Files, then install the driver station again, before the feed worked. Perhaps try that?
Unread 25-01-2010, 19:44
Team3256's Avatar
FRC #3256
for step 1, do you mean set our COMPUTER at 192.168.0.91 or the CAMERA at 192.168.0.91? because if we changed the computer's, wouldn't that affect our connection back to the cRIO?
Unread 25-01-2010, 19:47
Rookie Year: 2010
No I mean connect the camera to the router normally, make sure the IP for the camera is set to 192.168.0.90 (Just select Static IP in the settings) then connect the camera to the computer with a crossover cable, set the computer ip to 192.168.0.91, set the subnet mask to 225.225.225.0 and run the AXIS config utility on the desktop. It should read successful. Then go on to step 2.
Unread 25-01-2010, 19:58
Team3256's Avatar
FRC #3256
mkay, the AXIS config utility is the one with the same icon as the cRIO imaging tool right? or the one from the CD?
and do we put or computer back at the original IP address or leave as is?
Unread 25-01-2010, 19:59
Rookie Year: 2010
The one with the same icon as the cRIO imaging tool
I think the Driverstation will reset the ip when it starts, just restart the program if not then,
Put your IP back to what the driver station set it to. (10.xx.yy.5 or 10.xx.yy.6 not sure which one)
Unread 25-01-2010, 20:09
ProgrammerMike7 ProgrammerMike7 is offline
AKA: Mike
FRC #2200 (MMRambotics)
Rookie Year: 2010
ProgrammerMike7 will become famous soon enoughProgrammerMike7 will become famous soon enough
Hi, we have been having the same problem you have been having but I have recently fixed this. I posted detailed step-by-step instructions in this thread: http://www.chiefdelphi.com/forums/sh...ghlight=camera.
I hope this helps getting your camera up and running.
-Mike and Team 2200
Wait (-1)
Unread 25-01-2010, 20:19
Team3256's Avatar
FRC #3256
arrgh it was to no avail...we even tried threatening harm to the computer and it still didn't work. any other suggestions?
Unread 25-01-2010, 20:21
Rookie Year: 2010
Did you use my code exactly (I posted a copy/paste of my current robot code)? And find a way to verify that the code made it all the way to the robot, mine didn't ACTUALLY upload for half the evening today. Be sure to reboot the robot, the new code doesn't take effect until a reboot.
Unread 25-01-2010, 20:25
Team3256's Avatar
FRC #3256
do you know any way to check if it made it to the robot?
Unread 25-01-2010, 20:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The cRIO code expects to find the camera at IP address 192.168.0.90 (its default). Where did you pull the 10.x.y.7 number from?
Unread 25-01-2010, 20:36
Team3256's Avatar
FRC #3256
we found somewhere in directions to change it to 10.x.y.z, z being whatever wasn't taken.
we changed it back to 192.168.0.90 though.
Is anyone using the Camera? GillSt.Bernards General Forum 19 05-03-2009 21:52
improvements to demo camera code anyone windell747 NI LabVIEW 13 06-02-2009 21:22
Can anyone sell us their camera?? Athenian Roboti Kit & Additional Hardware 2 20-02-2006 07:16
For anyone who doesn't get the camera code..... Jake M Programming 8 16-01-2006 18:56
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
