Go to Post ....a red-light-of-death. - Kevin Watson [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 25-01-2010, 20:20
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Rookie Year: 2007
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Compass and/or Gyro
We are trying to determine the best way to get a true accurate angular heading of the robot.
2 Years ago we tried using the rate gyro, to some success, but to abrupt of a turn, or a jolt and we would lose our heading. It was however successful enough to help with our autonomous.
I've read of the idea of using a compass to periodically reset the gyro, so here is my question.
How would you determine when it is appropriate to reset the gyro's heading using the compass?
Is it better to do it based on an error percentage between the 2 sensors? or a time based reset period.
Thanks,
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 29-01-2010, 19:59
SavtaKenneth SavtaKenneth is offline
AKA: Yotam Kenneth
FRC #2212
SavtaKenneth will become famous soon enough
Re: Compass and/or Gyro
You should try using this year's gyro before deciding it's not good enough. FIRST massively upgraded the gyro between the 2008-2009 seasons so the current gyros are much better. Not sure as to how to use a compass to rese the gyro sorry.
~Kenneth
Team #2212 The Spikes
[FTC]: Lego compass sensor and pucks KayyPii FIRST Tech Challenge 3 23-11-2008 10:59
Gyro resetting and recalling? Tom Line Programming 1 17-02-2008 09:05
Gyro Compass Nathan Programming 5 16-01-2008 14:55
**FIRST EMAIL**/Purchasing 2007 FRC Game Pieces and Yaw Rate Gyro and Dual Axis Accel GNH2000 FIRST E-Mail Blast Archive 7 09-01-2007 18:38
