Go to Post Rules can be rewritten, problems can be fixed, but peoples' feelings are far from inanimate - they need more consideration than just being "corrected". - Eugenia Gabrielov [more]
Unread 25-01-2010, 21:58
baihooli3022 baihooli3022 is offline
None #3022
baihooli3022 is an unknown quantity at this point
Tank and Arcade Drive Help?
Hey guys,
I seem to have a problem with our controller's tank vs arcade drive. When we finally got the control system to connect to the cRIO, jaguars, etc, it automatically went to arcade drive. We tried putting the Z-Wheel on + and - for every possible combination, negative/negative, negative/positive, positive/positive, and positive/negative. Nothing seems to work. Any advice on how we can get our bot to go to tank drive?
Thanks in advance,
Chris from Team 3022
Unread 25-01-2010, 22:33
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Tank and Arcade Drive Help?
So far as I know, the supplied software does only Arcade drive. If you want Tank drive, you will have to modify the code. What language are you using?
Unread 25-01-2010, 22:36
None #3022
Uh, I'm not our main programmer, but I believe the language we're using is Labview, if that's not a language, then probably C+
Arcade Drive Issue and Pnuematics chenvoy NI LabVIEW 10 23-02-2009 20:03
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
Pointers and Tank Drive? Straberrie Programming 12 18-12-2008 19:24
Tank Drive help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Idaman323 Programming 3 18-02-2005 15:17
