Go to Post Remind me again. Why do we let the GDC hold us captive to these hints year after year? - jholman [more]
Unread 26-01-2010, 17:30
Oreoiorio's Avatar
Oreoiorio Oreoiorio is offline
Anonymous
FRC #0467 (Duct Tape Bandits)
Team Role: Student
Oreoiorio is an unknown quantity at this point
The Power of Servos
Servos aren't that powerful, but with a strain on the number of motors left to use, we need to use them. Using a lever, we got a single servo to release something with a strong force, but when we increase the opposing force, the servo is no longer powerful enough.
My question is, is there any way to double up two servos to pull on the same thing? If so does this method provide any extra power?
Servos aren't my thing, and I would prefer we didn't even use them, but right now a solution would be much appreciated.
Unread 26-01-2010, 17:35
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: The Power of Servos
I remember seeing a picture of a device that could gang 3 servos last year or the year before. Can't find it right now, but it's in CD-Media. (Trying to remember who posted it...)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 26-01-2010, 17:49
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
This picture Eric?
Unread 26-01-2010, 17:56
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Originally Posted by Vikesrock View Post
That one exactly.
Past teams:
Unread 27-01-2010, 12:06
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Doubling up the servo's would give you more power (torque), yes. Thing about the KoP gear boxes for the CIM's - you can stick two CIM's in there in order to increase the torque available on the output shaft at any given speed. You would need to buy or design some sort of linkage that works in the same way to combine the servo's.
What might be easier to do, however, is increase your mechanical advantage when using the servo's. This can be done through gear reductions, levers, pulley's, or any number of other methods. Simply put, you decrease the amount of torque the servo needs by increasing the distance the servo moves (rotates) to do the same job. It's like shifting down on a bike to get up a hill.
For example, if the servo is simply rotating a rod into place to hold something, and it requires a 90 degree turn to do so, put a small sprocket on the rotating piece, and another one on the servo, with a 4:1 reduction. Now you turn the servo 360 degrees, the rotating piece turns 90 degrees, and you've accomplished your goal while requiring less torque from the servo.
Unread 27-01-2010, 13:25
Oreoiorio's Avatar
Anonymous
Team Role: Student
Thanks for all the help, I think we figured out what we need to do.
Positioning the robot so the servos will be centered... Bomberofdoom Programming 2 02-02-2007 03:30
questions about the servos Alex Golec Motors 1 23-01-2005 20:05
How do the servos work? tml240 Motors 25 18-02-2004 07:47
Why MUST the 7.2v battery be attached to operate servos on the RC? Mike Rush Control System 17 06-02-2004 18:57
Calabrating the servos rust710 Motors 9 25-12-2002 20:41
