Go to Post Robot? What robot?! - LightWaves1636 [more]
Unread 26-01-2010, 19:56
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
Team Role: Coach
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Labview Programming Technique Question
Rookie Labview Programmer Question
Within the FRC LV framework, I see the Tele-OP vi and I see the periodic task vi. Based on examples I have studied, the joystick control goes in the tele-op vi. I now want to add a solenoid control for an air valve. This will be actuated by a joystick input. My question is does this go in the tele-op vi or in the periodic task vi?
More generally, what kind of tasks are typically are placed in the tele-op vi vs the periodic task vi?
Thanks for your help.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 26-01-2010, 20:41
bladetech932's Avatar
bladetech932 bladetech932 is offline
Programmer of awesome
AKA: Jon
FRC #0932 (Circuit Chargers)
bladetech932 is on a distinguished road
Talking Re: Labview Programming Technique Question
you put all controls in the telop you shouldn't need to use periodic task at all.
in periodic you put things like resetting inputs things you don't control
so yes solenoids,relays,gyros,motors all go in the telop
Unread 27-01-2010, 23:30
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
Well, there is a difference.
Use periodic tasks when you want something to execute at a certain rate, regardless of whether you receive a datagram from the Driver Station or not.
Use teleop for functions that require direct driver control.
-- Marshal Horn
Labview servo programming Delvadar NI LabVIEW 9 01-02-2010 20:29
Programming Mecanums in Labview Hadi379 NI LabVIEW 6 21-01-2010 19:45
FRC LabVIEW programming dlesley National Instruments LabVIEW and Data Acquisition 2 15-12-2008 13:21
Labview Programming question pollyproof12 General Forum 2 30-09-2008 16:29
Programming technique.. archiver 2001 3 24-06-2002 04:02
