Go to Post I did research before asking a question on CD..blasphemous I know - rachelholladay [more]
Unread 26-01-2010, 23:29
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
Team Role: Coach
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Exclamation HELP!! No readouts anywhere on dashboard
Classmate Setup:
Driver station has been updated
LabView updated to latest version (using LabView to program)
Classmate recognizes USB and E-Stop button (E-Stop button is plugged in to pc)
Hardware System:
Jaguars (we have two connected) - PWMs are seated correctly but lights are
blinking yellow
Jaguar update has not been run (cannot figure out how)
cRio -Ethernet is active on port one
Status light comes on when cRio first powered but then turns off (is
this normal?)
Ip address set correctly to team number
Running update v.19
Analog - slot 1 - solid green light
Soleniod breakout - slot 8 - solid green light
1 - CIM Motor connected to each Jaguar
Digital Sidecar - solid green lights on 5v and 6v
blinking green light under RSL
Example code is being loaded and run from the Developer account
Load the example code to the cRio it is accepted with no errors
When the example code is run all of the lines are flat even the joystick
HELP we cannot figure out what's going on!!
Could it be that we have not run Jaguar update and if so HOW do we run the update?
When we have the Driver Station (in the driver account) open, the joysticks and E-Stop are recognized. However in the Developer account when we run RobotMain.vi (example code) and move the joysticks the readout line remains flat...
What are we missing?
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Dashboard-Driver Station Help Please sircedric4 C/C++ 18 21-01-2010 22:50
[Help Needed] Camera to Dashboard basicxman C/C++ 1 19-01-2010 18:20
Dashboard Help C++ Windriver ranc Programming 0 15-01-2010 15:26
Past competition video archives available anywhere? Japper General Forum 2 07-01-2008 12:32
