Hey I need some help with the Driver Station. I am unable to run code because the "Robot Code" light in the DS is red. I Tried redownloading the example code it the Control System Manual told me to download to the cRIO, but it still did not work. Is there something else i need to do? Please Assist.
Re: Red Robot Code Light in the Driver Station (Using C/C++)
If you look at the serial output, it will display error messages and help determine the cause. The issue is likely caused by an old cRIO image or an old version of WindRiver tools.
Greg McKaskle |
Have you completed all of the available updates for the driver's station, cRio, and windriver workbench?
The number cause of this issue (that I have seen) is not updating everything properly. Also check this thread- http://www.chiefdelphi.com/forums/sh...ad.php?t=80194 |
See this thread:
| Robot code isn't loading onto driver station | TigerDrive2391 | Programming | 2 | 24-01-2010 15:32 |
| Deploying code from the 2010 driver station - Netbeans | joshholat | Control System | 5 | 23-01-2010 15:01 |
| Driver station not detecting robot code | captainking | NI LabVIEW | 9 | 21-01-2010 10:39 |
| using digital inputs from the driver station | SL8 | NI LabVIEW | 2 | 04-02-2009 15:53 |
| GTS Code Error (the red light of doom!) | Denz | Programming | 9 | 07-04-2006 17:39 |
