Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
Unread 27-01-2010, 15:28
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Testing Help
Is there some way that i can just have labview open on another laptop computer and just click the run command to test the code and edit on the fly. As opposed to logging on developer, build the code, run as startup, open driver station then it doesn't work, change the code, build the code, test and repeat.
Help with Testing Joystick jo3_sum NI LabVIEW 3 17-01-2010 21:18
Axis Camera Testing help koo_04 Programming 7 20-12-2008 13:55
Help testing RoboEmu 1.10 rbayer Programming 26 27-01-2003 06:50
Testing Jack Website Design/Showcase 0 27-12-2002 22:14
testing team222badbrad Chit-Chat 5 15-01-2002 09:49
