Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 27-01-2010, 17:58
guitarbonham guitarbonham is offline
FRC #3023
guitarbonham is an unknown quantity at this point
Connecting Solenoid to CRIO
I know where the dual valve solenoid is supposed to be plugged into the solenoid breakout, but I can't find anything in the KOP to connect the wire to the two prongs on the solenoid breakout. does anyone have any recommendations on how best to do this?
What guage wire is required to connect it?
thanks!
connecting to Crio using windriver Tds123 Programming 1 27-01-2010 13:21
Trouble connecting to cRIO? darty Programming 17 31-01-2009 16:15
Connecting to the cRIO lingomaniac88 Programming 1 30-01-2009 10:58
Connecting Axis camera to cRIO laultima FRC Control System 20 21-01-2009 16:56
Connecting Power Distribution block to cRio Paul Rodi Electrical 2 05-01-2009 18:20
