Go to Post So yeah, everyone please remember that lathes are one of the most dangerous machine tools you'll encounter. And keep your hand on the chuck key whenever it's in the chuck. If you never let it go till it's out of the chuck, it's stupendously less likely to take flight. - Kevin Sevcik [more]
Unread 27-01-2010, 20:45
kngscrpn24 kngscrpn24 is offline
Student VP and Programmer
AKA: Ed C
FRC #2064 (Panther Project Robotics)
Rookie Year: 2007
kngscrpn24 is an unknown quantity at this point
Question WHAT'S A FAN!?
Hello all,
After four years in FIRST, I still have no idea what a fan is officially classified as. While I must admit I merely scanned the manual every year, this year, as a team leader, I took it upon myself to search out the answer to this question- to no avail (I actually read the manual-!!). Every year we get fans in the KOP, yet only this year have we considered actually using them. SO my questions here are severalfold:
1. What is a fan classified as- "motor" or electronic circuit?
2. What interface is required for a fan? If fans be "motors", then a speed controller is necessary. If not, then I inquire as to what is exactly meant by the power distribution diagram when it has a blank box with terminals marked "fans"- does this warrant me to put in, say, an old breaker-board specifically for fans.
3. Following upon #2, what breaker should be used? The majority of fans in this world only use maybe an amp or two. Somehow, a 20A breaker seams to defeat the purpose of having a breaker.
4. If fans be not a "motor" does that allow the use of non-KOP fans- that is, simply a CPU cooling fan, since it is the ideal size for cooling medium items.
5. If a fan be not a motor, what size wiring should be used to connect to the interface.
I know these questions are a bit extensive, but as far as I can tell, the manual doesn't have a sections devoted to these little creatures OR even the slightest mention (except for the Victor's fans) of them.
HELP!
-Ed C.
VP & Senior Programmer
Team 2064
2007 Rookie Inspiration Award
pic: S.P.A.M fan volcom248 Extra Discussion 4 17-02-2009 09:29
Large Fan Torboticsmember Electrical 7 08-02-2008 08:08
light up fan Dremel Drew Electrical 9 08-02-2007 23:28
Fan Club! TheManTheMyth Chit-Chat 3 29-10-2006 07:30
COOL Fan!!! Murf the Smurf Electrical 4 07-02-2006 20:54
