Go to Post I Don't like to think in the Box so i try not to make robots look like them. - Tytus Gerrish [more]
Unread 27-01-2010, 22:39
Jester Jester is offline
Labview Maniac
AKA: Cody Ripley
FRC #3144 (Krypto-Knights)
Jester is an unknown quantity at this point
How to assign buttons?
I am the only programmer on my team and am completely lost.
I have the camera with 2 servos(mounted), but I want to make it able to move the servos with joystick buttons. I want to use buttons 2,3,4,5.
Unread 27-01-2010, 22:40
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
Team Role: Leadership
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: How to assign buttons?
Can you let us know what language you are using?
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 27-01-2010, 22:43
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
I'm going to assume he posted in the right forum and is using Labview.
What do you want the buttons to do to the servo positions? Do you want them to move the servos to some setpoint? Or increment the servo position some amount in a given direction?
Unread 28-01-2010, 07:45
Are you starting with the 2010 Sample code? If so, it already reads several joystick buttons. The computer I'm at doesn't have the latest code installed, but if you open the TeleOp.vi file and go to the diagram, you can follow where the joystick wire leads. It may be easiest to drop another Joystick Get function and unbundle the buttons. Wire the buttons to case structures that add, subtract, or leave the desired servo angle alone. Then wire the angle to the servo.
If you haven't already done it, you'll want to add the Servo Opens to Begin.vi, store the value under some named entries, and read the refnum back in TeleOp.vi.
If you are not sure what something does, open and read examples. Also, much of what you need is in the WPILib section of the menu, towards the bottom.
Greg McKaskle
How Many Buttons? Beth Sweet Regional Competitions 13 17-12-2006 21:32
Buttons, Buttons and more Buttons (2006) Freddy Schurr Team Organization 11 14-12-2005 21:36
Can we assign alternate text for [img] and/or [img2] tags? Greg Ross CD Forum Support 2 01-11-2005 14:51
How many buttons do you have? Bcahn836 Chit-Chat 12 01-09-2004 23:34
How many buttons??? purplehaze357 Championship Event 0 18-04-2002 23:54
