Go to Post All the robots win, because we built them and they work. ;) - synth3tk [more]
Unread 01-27-2010, 11:58 PM
joshholat joshholat is offline
FRC #0930
joshholat is an unknown quantity at this point
Dashboard alteration in Java and setting start up programs
My question is twofold when it comes to using the Java development system as my team is.
1) How do you burn a Java program to the cRIO as the startup program? My team hasn't been able to figure this out. Can you even do that yet? Is it as simple as building a project in a certain way and importing it into LabView somehow to use with the NI burning tool?
2) I know the Dashboard VI can be altered to make it fit your teams needs more. However, I also know that the Dashboard is heavily based on LabView. When using Java, is it possible to alter the Dashboard VI and have a way in the Java API to send data to the LabView API to output in real time vs having to use println statements? I know the DashboardLCD class can be used to output text to the Dashboard, but we want to be able to use controls, etc.
Unread 01-28-2010, 12:21 AM
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: Dashboard alteration in Java and setting start up programs
1) Any time you do a "Run" of your robot program from netbeans you are "burning the code" to the cRIO. Once you have the cRIO imaged with the current version (currently v19), you don't need to use any labview tools to develop/deploy Java robot apps.
2) The short answer is "yes". Check out the sample apps in File/New Project under "Samples"/FRC Sample. Then check the docs and forums for additional info.
Unread 01-28-2010, 12:48 AM
FRC #0930
1) So once I deploy code, it's on there. Therefore, the latest code should just start going if I log on to the Driver account on the Classmate and connect to the robot at any point in time? Awesome!
2) Create a new project in LabView or in NetBeans? I know the Dashboard class for Java can put text on the Dashboard VI, but does it also interact with the GUI stuff?
Unread 01-28-2010, 10:21 AM
derekwhite's Avatar
In NetBeans. Good luck!
Setting up your new Classmate for Java technology Techwiz Java 2 01-10-2010 11:46 PM
**FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION*** Pjohn1959 Programming 37 08-31-2009 03:55 PM
Setting Dashboard UserBytes bobpskier Programming 2 02-05-2007 09:36 PM
Dashboard Programs? EHaskins Programming 5 01-31-2006 02:01 PM
Dashboard programs and the char variable Ian W. Programming 13 06-26-2002 02:07 AM
