Go to Post On the other hand, if the tires were marked "NOT FOR FRISBEE SHOOTER USE" I'd be worried. - Ken Streeter [more]
Unread 28-01-2010, 08:14
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
the behavior of the cRIO is no green light??
the behavior of the cRIO is no green light suddenly. NO power on.
It works perfect from January 2009 up today.
I have 24[V] by measuring the to ends of the wire which connected your 24V power supply to the power distribution board and the connected your cRIO to the 24V cRIO power supply terminal on the power distribution board.
What is wrong.
TEAM 1946-Tamra
what is the green light on the cam? (was: I NEED YOUR HELP!) RDD Programming 3 02-02-2007 08:01
PROBLEM - the cmaera doesnt detect the GREEN LIGHT razer Programming 4 30-01-2007 00:48
Following the Green Light with robot. Wompas Programming 0 26-01-2007 17:34
Lights (not the green target light) FourPenguins Electrical 10 23-01-2007 13:23
camera trouble,cant tell the green-light from regular white light Nimmy Programming 26 14-01-2007 14:53
