Go to Post Real coaches dont use "strategy assistants" during matches. - Rick [more]
Unread 28-01-2010, 16:31
Darth Pbal's Avatar
Darth Pbal Darth Pbal is offline
AKA: Paul Ronquillo
FRC #2375 (Biohazards)
Darth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud ofDarth Pbal has much to be proud of
Trouble Hit!
I'm trying to re-image my cRIO but I'm having trouble. Can someone tell me how I'm supposed to connect my computer to the cRIO to re-image it. Also some really explicit directions would be super helpful since I'm running my imaging tool on the cRIO but it's saying it can't find it.
-Go Team 2375!
Darth Pbal
Unread 28-01-2010, 17:41
plusk01 plusk01 is offline
AKA: Parker Lusk
FRC #1742 (Shockwave)
plusk01 is an unknown quantity at this point
Re: Trouble Hit!
You need to connect the cRIO directly using a ethernet crossover cable (the pink cable this year).
First thing you need to do is install the Mandatory LabVIEW Update on the Classmate, found here: http://www.usfirst.org/roboticsprogr....aspx?id=10934
Then install the Mandatory Driver Station Update on the Classmate (found on same link)
After the updates are installed, connect using the crossover cable and change the Classmate's IP address to 10.xx.yy.5, where xx.yy is your team number.
Run the 'FRC cRIO Imaging Tool.' It should say "Version Number: 2009.12.11.00" in the bottom left hand corner.
Choose the Development Environment of your choice. If LabVIEW, check the 'Always run deployed code at startup' option as well.
Then check 'Format Controller', name your cRIO device, and enter your team number in the 'Team ID' field.
Make sure the selected image is 'FRC_2010_v19.zip'
Click apply and follow on screen instructions. You should get a message after about 5 minutes saying format and re-image successful.
All these steps should be outlined in the 2010 Control System Documentation - Chapter 2: 2.6 STEP 6 CONFIGURE THE CRIO
USB Specification (Don't hit me!) Total Meltdown Programming 8 07-03-2007 20:26
Inventor software trouble/ FIRST Base trouble nasa-senpai General Forum 2 24-01-2007 09:15
The Village: Hit or Miss? Michelle 236 Chit-Chat 7 16-08-2004 01:59
We hit 300 again archiver 2001 1 24-06-2002 04:18
And then it hit me.... Joe Johnson General Forum 12 07-02-2002 22:29
