Go to Post FIRST has stated time and again that the program is not about teaching (they always refer to the I and R in FIRST) - Dave Flowerday [more]
Unread 28-01-2010, 17:35
Tzaddik Tzaddik is offline
FRC #3267
Tzaddik is an unknown quantity at this point
Wireless Problems
We went through all of the steps in the book up untill the step to enter the new bridge ip, (10.xx.yy.1), and when we enter this into the web browser, nothing comes up. We can get into the router settings fine, but not into the bridge. When we change the network name of the router to our team number, it stops broadcasting a wireless signal. We have done many hard resets, and have tried doing everything over quite a few times. If some one could help out, we would appreciate it.
Unread 28-01-2010, 21:32
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Wireless Problems
I assume you are following the steps in the order they appear in the manual. Once you set the new IP, your wireless router will not communicate with the bridge until the router setup is completed.
Unread 29-01-2010, 09:42
greglaston greglaston is offline
FRC #3204
greglaston is an unknown quantity at this point
I had the same problem until I noticed that the wireless card in the laptop is 802.11g, but the instructions say to use 802.11b only. After changing router and bridge to communicate using mixed 802.11b & 802.11g, I got a nice strong signal.
Unread 30-01-2010, 09:11
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
FRC #3132 (The Thunder Down Under)
Team Role: Animator
Rookie Year: 2010
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
Check that you are not on the same band as another wireless network nearby.
We had connection issues before and it turned out that the University wireless is running on the same band as ours. So we changed that and it works like a charm.
wireless bridge problems tanguma26 Programming 8 31-01-2010 11:16
Wireless Bridge Problems furiousgeorge Control System 9 28-01-2010 13:28
Jaguar and wireless problems. Team_2547 FRC Control System 1 26-01-2009 16:54
New Control System - Wireless Problems Ashwin FRC Control System 13 11-12-2008 10:38
Linux Wireless Card Problems Mike Chit-Chat 3 03-01-2006 03:57
