Go to Post Heat Gun(n.):Your build season replacement for a microwave. - jajabinx124 [more]
Unread 28-01-2010, 18:37
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Team Role: Mechanical
Rookie Year: 2007
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
Transmission Video
Hey, I was wondering if anyone had a video of an Andy Mark transmission in action, preferably one of the earlier models so that I can see the inner workings. I know technically how it's supposed to work, but I'd feel a lot better if I could see one moving.
And also, while I have your attention, I was wondering what everyone thinks about using a transmission for the kicker, since that's what we're planning. My biggest worry is that using the shifter so many times could possibly ruin it. I've read some people saying they've had problems with it, and some people saying they haven't, so I was hoping to get a better idea for that too.
Thanks for any help.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 28-01-2010, 19:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Transmission Video
I remember there being a great CAD cutaway picture on here that showed the shaft, gears, dog, pin, and shifting rod. From back around 2003. It was colored blue, green, orange, etc for the different pieces. Anyone know the picture I mean? I couldn't find it.
Unread 28-01-2010, 20:13
DonRotolo's Avatar
Back to humble
FRC #0832
Send Andy or Mark an e-mail (or phone call) and ask them. Nobody knows better what their trans can and can't be expected to work well as. Try to describe exactly how you're using it, drawings will help, if you want their best answer.
They are really nice guys and will take some time to answer you.
Unread 28-01-2010, 21:25
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Rookie Year: 2007
Yeah, I was planning on giving them a call tomorrow to check on the feasibility. But I'd still really like to see a video or a more detailed picture than the one on their website if anyone has one. I have a feeling if they tried to explain it to me over the phone, I'd just get confused again. Visual learner and all....
Unread 28-01-2010, 22:07
What exactly is it that you are trying to figure out or visualize? Ours and other teams we are friends with are all using shifters in the kicker, if you just ask we'll be happy to explain the mechanisms at work.
Unread 28-01-2010, 22:19
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Originally Posted by AndyMark.biz
Video of Assembly Instructions
Toughbox Assembly Video (right click, Save As)
That should do.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 28-01-2010, 22:55
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Rookie Year: 2007
I just want to see exactly how the mechanism to shift works. I understand that you have a dog gear that moves along a shaft, disengaging and engaging the gears you want to use. But I don't really understand how the servo/piston works to do this. I guess what I really need to see is just a video of someone shifting one of them or a picture that makes the system easy to see.
Originally Posted by Alex Cormier View Post
That should do.
Not exactly, that's a toughbox. We know how to put those together But thanks anyways!
Unread 28-01-2010, 22:59
Black = actuator
Blue = shifting block. The shifting block houses a bearing and a shaft that connects to your dog gear. The dog has a steel cotter pin going through it that allows it to slide back and forth in the slot in the hex shaft. The dog engages and disengages the drive sprocket (or whatever you're trying to shift).
http://ep.yimg.com/ca/I/yhst-3383317..._2090_36957746
http://ep.yimg.com/ca/I/yhst-33833170891817_2090_641582
That is the shifting block. On the other side is a drilled and tapped hole for your actuator. The shaft that you see has a through hole at the end for the cotter pin.
Hope that helps.
Unread 28-01-2010, 23:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Dog shifter failures of various types aren't uncommon when the actuator slams the dog hard against the gears. If things are tuned and spaced so that the dog doesn't quite get pushed all the way, such failures are uncommon.
Unread 29-01-2010, 00:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
http://www.chiefdelphi.com/media/photos/15892
2001-2004: Team 100
2006-Present: Team 254
Unread 31-01-2010, 20:54
yoshibrock's Avatar
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
Rookie Year: 2007
Thanks a lot everyone! I didn't realize that other people had actually commented on the thread, as it had disappeared from the front page, so I apologize for not thanking you guys in a more timely fashion. The colored CAD breakup helped a lot, and I think I understand exactly what's going on now.
[TBA]: h.264 Video Analysis, and Improving TBATV Video Quality artdutra04 The Blue Alliance 5 29-09-2008 00:29
pic: SWAT 2008 Robot--Short Video Clip at http://smithvillehighrobotics.com/video.htm SWAT1806 Robot Showcase 5 27-02-2008 14:00
[Comedy Video]: Team 228's 2007 Summary Video! artdutra04 Chit-Chat 0 01-03-2007 23:21
Team 1817 Bike Motor 2 Speed Transmission Video 118 Tech Robot Showcase 0 14-02-2006 22:56
Video: Cyber Blue 234 Late Night Programming Video JAH Robot Showcase 6 13-03-2005 00:34
