Go to Post If your goal is to win matches... Pick the most capable candidate. If your goal is to change lives... Sometimes you pick those that need the most change. - IKE [more]
Unread 29-01-2010, 12:26
Tds123's Avatar
Tds123 Tds123 is offline
There is no I in team =]
AKA: Timothy Shub
FRC #1396 (Pyrobots)
Rookie Year: 2007
Tds123 is an unknown quantity at this point
Send a message via AIM to Tds123
Programming help go foward but not reverse
Here is my robots code...
http://paste.pocoo.org/show/171676/
The spike that run " winch"
and the spike runs "roller" the button that makes it go foward works but the buttons that make it go in reverse dont work...please help with this someone!!!
and the jaguar for arm... when both buttons are pressed the jaguar turns green one of them is supposed to be red for reverse...
ThE sCaLeS oF bAlAnCe (Team 1396)
Unread 29-01-2010, 16:56
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Programming help go foward but not reverse
you are turning it off
Code:
if (armjoy.GetRawButton(outtakeButton) == 1) {
			roller.SetDirection(Relay::kForwardOnly);
			roller.Set(Relay::kOn);
		} else if (armjoy.GetRawButton(intakeButton) == 1) {
			roller.SetDirection(Relay::kReverseOnly);
			roller.Set(Relay::kOn);//not kOff
		} else {
			roller.Set(Relay::kOff);
	if (armjoy.GetTrigger() == 1) {
				winch.SetDirection(Relay::kForwardOnly);
				winch.Set(Relay::kOn);
		} else if (armjoy.GetRawButton(winchDownButton) == 1) {
				winch.SetDirection(Relay::kReverseOnly);
				winch.Set(Relay::kOn);//not kOff
		} else {
				winch.Set(Relay::kOff);
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Help!!! Default programming does not work? WolvesRobotics C/C++ 4 08-02-2009 14:10
URGENT HELP: IR board TRAINS but does not RECIEVE dan_h Sensors 6 20-02-2008 20:31
reverse of motors NOT working please help Stillen Control System 4 11-02-2006 22:05
New to C but not to basic, need help on autonomous cdennisxlx2 Programming 4 02-02-2005 03:38
not robotics, but help would be appreciated pryoplasm Electrical 26 02-06-2004 07:14
