Can anyone confirm or deny that the 8" Mecanum wheels from AndyMark (AM-0083) actually fit width-wise inside the 2010 KOP wheel brackets (AM-0450)?? We are trying to lay hands on the wheels, but AndyMark isn't quite ready to ship them just yet. We want to make sure they would fit inside the KOP brackets. Looking at the CAD files and stuff, it appears that they will. I just want to make sure there's enough room for a spacer and sprocket as well.
Re: 8" Mecanum wheels and KOP wheel brackets
Our team determined that the 8" AM mecanum wheels do NOT work with the KOP wheel bracket.
We are working on our own brackets right now. EDIT- sorry, read your post again. They DO fit width-wise, they do not height-wise. We considered cutting it to accommodate the wheels, but decided that it wouldn't be very structurally sound. |
We were thinking of just notching out the top, up to where the opening gets larger. We were just afraid of the width, with the wheels being 2.52" wide already and the opening seemingly less than 3"...
The width of the KOP bracket isn't really wide enough to hold the wheel WITH a sprocket and chain. We had to cut it wider and also bend it out a bit, which took a lot of the strength out of it. It worked fine for a prototype, but I would suggest making your own brackets for your final robot.
we made some super-simple brackets : 2 9" pieces of plate aluminum on either side of the area in the kitbot chassis that would attach to the regular wheelmount. drilled new holes near the hole-pair and bolted them on. works brilliantly
From the AndyMark site.
We decided to make our own brackets though since we want to drive the wheels directly and the angled design of the brackets make adding bearings and mounting the transmission more difficult. Last edited by TubaMorg : 29-01-2010 at 23:11. |
-dave . |
Plus, as it's been said, you cannot fit a spacer, sprocket, ANSI 35 chain, and bolts all in there.
If you're just trying to prototype mounting options, here's one that seems to have worked for another team. The brackets are simply shelf cross members you can buy at the hardware store: http://www.youtube.com/user/SteveJes.../1/UQQ67SB8Acc As another poster said, I would strongly suggest working up some CAD for a sturdy mounting system of your own design, as opposed to planning on using the KOP brackets or something similar to the YouTube video... |
#10
It actually says on the Andymark website that they don't quite fit:
"For Use in 2010 FIRST Robotics Competition These wheels fit within the AndyMark Wheel Bracket, with a bit of modification for sheet metal removal around the wheel, and if the interior screws on the wheel are shortened to 2.5" long screws instead of 3" screws." |
| AndyMark 10" Mecanum Wheels | ChuckDickerson | General Forum | 7 | 31-12-2008 12:54 |
| Need KOP 8" Wheelchair Wheels | dapub | Kit & Additional Hardware | 4 | 22-02-2008 12:22 |
| Friction coefficients for Omni wheels and Mecanum wheels from AndyMark | Andy Baker | Technical Discussion | 11 | 16-12-2006 19:40 |
| pic: 2" Mecanum Wheel | Tytus Gerrish | Technical Discussion | 17 | 22-04-2006 12:22 |
| omni wheel instead of mecanum wheels | Leav | Technical Discussion | 4 | 15-01-2006 18:53 |
