Go to Post So now that the Championship is over, how long 'till next kick off? ;) :p - Michelle Celio [more]
Unread 29-01-2010, 18:00
1168Programmer 1168Programmer is offline
Head Programmer/CEO
FRC #1168
Team Role: Student
1168Programmer is an unknown quantity at this point
Lost the camera part of the dashboard...
Somehow the top half of our dashboard (the part with the camera viewing and solenoid outputs) disappeared. We do not know how or why, but we can see the bottom half and the background. If anyone has any suggestions or has encountered this problem before, please help us!
Unread 29-01-2010, 18:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Lost the camera part of the dashboard...
You've told the Driver Station to use a remote dashboard, so it doesn't start the local one. Set it back to local if you want to see the feedback on the Classmate PC.
Unread 30-01-2010, 09:51
Head Programmer/CEO
FRC #1168
Team Role: Student
The dashboard is set to local, but it shows up in the developer user, not the driver user. Is there any way to fix this?
Unread 03-02-2010, 10:27
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
How do u set it to local? Where do you go ? Please tell me the specific location to change it thank you
-Chinmay
Unread 07-02-2010, 13:51
Head Programmer/CEO
FRC #1168
Team Role: Student
In the Driver user, under the Setup tab, on the lower left there are two switches. One says Local Dashboard (this is the one you want to select) and the other says Remote Dashboard. If you have Remote Dashboard selected, it asks for the IP address of your dashboard. Make sure Local Dashboard is selected and it doesn't ask you for an IP address.
Does this help?
Unread 15-02-2010, 10:30
Head Programmer/CEO
FRC #1168
Team Role: Student
We used the restoration key to reset the classmate and reinstalled the driverstation and dashboard and it works now. Don't know how much help this is to anyone...
Can we use the camera image on Dashboard this year? Jon236 Programming 1 11-01-2010 12:52
Knocking the ball off: A viable and important strategy lost in the whims... Brandon Holley Rules/Strategy 15 09-03-2008 16:15
Part Three: The FIRST Robot Rock Opera: The Humanity League Gabe Salas Jr. General Forum 2 14-03-2007 17:58
IT'S ALIVE!!!!!!! WE WILL CONQUER THE WORLD WITH THESE!!!!!! (Part 2) THE MOVIE sgsdragons Robot Showcase 20 16-02-2006 10:46
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
