Go to Post Once this competition is over, we should donate all of these Poof balls to daycares, elementary schools, neighbors; all the little kids. It would make us look good like, "Here's our Toys for Toddlers gift from us upstanding citizens. And we build robots." - atomikitten [more]
Unread 01-29-2010, 10:22 PM
Robopanda6 Robopanda6 is offline
FRC #2477
Robopanda6 is an unknown quantity at this point
Making Program Wireless
This is my first time using Java and I am wondering how to make the program run Wirelessly. I have experience making a program wireless using Labview but not sure if it is the same with Java. Could anyone tell me if you use the same procedure or what is the proper way of making the program wireless? Help would be much appreciated and I'm sorry if I sound repetitve.
Unread 01-30-2010, 12:27 AM
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
Re: Making Program Wireless
I dont know about labview but it should be the same steps I assume. The way i have had it set up is just connect to to the router via wifi. and set your ip to the right setting and you should be good. make sure u disable the lan port sometime it will try to connect thro it. if you want wireless from the robot just follow instruction in the control system pdf.
Unread 01-30-2010, 01:17 PM
FRC #2477
If you are using the classmate does that mean you don't need the blue driver station box anymore? Also, do you still the wireless router on the control station if you are using the classmate?
Unread 01-30-2010, 09:39 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
That is correct, you don't need the blue kwikbyte driver station, the classmate takes its place. You do still need the wireless router. You should read the control system manual at http://usfirst.org/frccontrolsystem
Wireless Problems Tzaddik Technical Discussion 3 01-30-2010 09:11 AM
Wireless Thermometer Wireless Data C222 Technical Discussion 9 01-11-2010 08:01 AM
Making program print form SyNtHeSiS Programming 1 07-01-2009 05:00 PM
Making the Labview program stick CDlabrador National Instruments LabVIEW and Data Acquisition 3 01-13-2009 08:19 PM
Wireless Question! mynameisbob Technical Discussion 5 01-11-2009 10:11 PM
