Voltage not outputting to the Drivers Station
We can get the robot to communicate, the USB hub is connected and detected and We get the connection down, but the voltage will not output to the Driver Station, even though we have the jumper in the correct place.
![]() Last edited by Ryutso : 01-30-2010 at 12:15 PM. |
Re: Voltage not outputting to the Drivers Station
Can you confirm you have both reimaged your Crio - AND updated, then uninstalled that update, then reinstalled that update on your classmate? Lack of a proper dashboard update will result in messed up connectivity.
Do you get the Analog Bumper power LED lit?
Is it in cRIO Module slot 1? |
You need to put some basic code on before the voltage will show.
What update are you speaking of? There were many we did. Quote:
Yes it's in slot 1 I've never worked with LabVIEW before. Do we run the LabVIEW code from the Devloper or the Driver account? |
When you reimaged the cRIO that leaves no user code on it.
The Robot Code and Communications status lights on the Driver Station must be green for voltage readout to work. There are a couple of ways to run LabVIEW code.
What is the NI number on the Module you have in slot 1?
From your photo it looks like you have the Analog Breakout board mounted on the Solenoid Module (NI 9472) (it has 8 little green LEDs on it), instead of the Analog Module (NI 9201) (no LEDs). P.S. I can't see your photo at work or school the way you attached it. I only happened to see it while browsing from home. Otherwise, I would have mentioned it sooner. Last edited by Mark McLeod : 02-09-2010 at 10:49 AM. |
Wow. What an amazingly simple solution to a problem that has plagued us for a while. It is the NI 9472 module we attached it to, but I can't find the Analog Module NI 9201. Uggh. Thanks Mark.
Now I turn to my team to find the correct module. |
| Driver Station not displaying Battery Voltage | Doc Wu | FRC Control System | 7 | 02-23-2010 04:03 PM |
| Drivers station problems | Chris11246 | Programming | 7 | 02-16-2009 07:36 PM |
| Drivers Station Magical Current | 3DWolf | Electrical | 5 | 01-25-2009 09:52 PM |
| Telling the drivers station your alliance | Mike Mahar | Technical Discussion | 2 | 01-17-2009 12:24 PM |
| PWMs not outputting in Autonomous | 937Programmers | Programming | 15 | 02-08-2007 09:25 PM |
