Camera custom config
I have the camera working.
I am including the Vision\\AxisCamera2010.h file. If 2009 it said to run the StartCamerablabla function. That is in the 2009 h files. When I include bothe the 2009 .h files and 2010 .h file I get conflicts. So how do I set the frame rate in 2010? Is the camera running in its own thread? How can I get the camera to run on its own thread? Any help is appreciated. |
Re: Camera custom config
The camera already runs in its own task. The frame rate is not controlled by the task since the code is using the mjpeg interface which means the camera is constantly streaming back images. The task does not request each image.
Also, you can configure the max frame rate in the web configuration for the camera.
| Starting Config question | Woody1458 | General Forum | 8 | 11-02-2008 01:19 |
| Portal Config Fixes | Brandon Martus | Announcements | 0 | 28-06-2006 13:27 |
| Camera Config doesn't save! | comwiz7 | Programming | 2 | 20-02-2006 17:19 |
| Load config from file | Bruce Barber | LabView and Data Acquisition | 1 | 31-01-2006 09:46 |
| pic: 1018 Final Config. | CD47-Bot | Robot Showcase | 17 | 24-02-2004 22:10 |
