Go to Post Do not under estimate the wood bots and brave little toasters! - hipsterjr [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 30-01-2010, 12:55
Akademee Akademee is offline
FRC #0888
Akademee is an unknown quantity at this point
Open AutoDesk files in SolidWorks
Hello Chief Delphi,
My task for this season is to CAD our robot in SolidWorks, however, I have been unable to locate a contiguous 2010 kop for SolidWorks. I know that there is the 3D Content Central, except out of the hundreds of files there are, I cannot seem to download it in one package. I also know that ProE files can be immediately called up in SolidWorks, but every single part file from the ProE directory needs to be extracted one by one by hand and has become very impractical as there are hundreds of files.
However, I was able to fully download and extract very good looking parts from the AutoDesk Directory. I need to know if there is a way to open these parts in SolidWorks. When ever I attempt to alter any "Options" in the "Open" menu, it only leads to SolidWorks, in essence, becoming disabled and will not perform any other functions as it says the program is busy. If there is a converter or any other "options" settings that need to be changed, I would really appreciate any help with this issue and I can get this robot designed.
Thanks Chief Delphi!
Solidworks KOP files nittemare SolidWorks 7 15-01-2012 18:00
Call up Pro/E files in SolidWorks TroyCDH SolidWorks 1 12-01-2010 19:29
Is it possible too import the Auodesk Files to Solidworks? vmuralidharan Inventor 2 10-01-2009 14:41
How to create 3D dxf files in Solidworks, Inventor, or other? Travis Covington SolidWorks 6 03-05-2006 21:46
Solidworks Files Panther378 Technical Discussion 1 21-01-2006 22:34
