Go to Post The honor from any given job is not so much what you are doing, but how you do it; the hardest working garbage man deserves more honor then the laziest super hero. - Josh Hambright [more]
Unread 30-01-2010, 13:11
koo_04 koo_04 is offline
FRC #2493
koo_04 will become famous soon enough
Direct to wheel
I dont know if this is the right place to put this, but I was wondering the best way to mount the wheels directly to the gearbox output shaft? We want to stray away from using chain and sprocket this year. Please help. Thanks!!!
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
Wheel direct drive molly Technical Discussion 15 25-01-2008 00:32
Direct Joystick Access billdar Programming 2 27-01-2007 22:43
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
