Go to Post It would be interesting to be able to take robots from multiple years and invent new games they can play together (Calvin Ball). - Mark McLeod [more]
Unread 30-01-2010, 13:34
Phreadumb's Avatar
Phreadumb Phreadumb is offline
FRC 2188 Alumnus
AKA: Dakotah Jones
Phreadumb has a spectacular aura aboutPhreadumb has a spectacular aura about
Download Labview 8.6 to cRIO
I'm trying to download my Labview program to the cRIO. The program is debugged, the cRIO is connected, but Labview 8.5.1 is currently installed on it. Is there any way to get Labview 8.6 downloaded to the cRIO?
I will be trekking into territories where FIRST teams do not exist, perhaps I should start one? Oh, but that's a lot of work.
Unread 30-01-2010, 17:58
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: Download Labview 8.6 to cRIO
You don't download Labview 8.6 to the Crio. If you've followed the directions in the controls manual, you should have already updated both your driver station and your Crio to Image Version 19. Have you done so?
Unread 30-01-2010, 23:45
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
It sounds like you might have last year's image on the cRIO. You need to reimage the cRIO with this year's (2010) cRIO image. If you installed the 2010 FRC software (I'm assuming you must have because you have LabVIEW 8.6), then the FRC cRIO Imaging Tool shortcut should be installed on your Windows desktop.
-Nate
Need to manually reboot cRIO to download code FRC4ME Java 6 24-01-2010 15:59
Download from Crio to Labview MachineSMMC NI LabVIEW 3 16-10-2009 13:37
Cannot get Code to Download to cRIO greekgod8591 C/C++ 25 09-03-2009 22:10
Crio image download brainsdmaner FRC Control System 2 15-02-2009 01:06
Download Programs Off the cRIO jwdickson FRC Control System 1 10-01-2009 17:29
