Go to Post I wouldn't recommend using steel because it will eat up your weight budget pretty quickly. - Scott Morgan [more]
Unread 30-01-2010, 14:35
sp33chy sp33chy is offline
FRC #3332
Rookie Year: 2010
sp33chy is an unknown quantity at this point
Wireless bridge issues
I am following the manual to set up the wireless bridge. I can access 192.168.1.250 and get to the login screen, but the credentials do not work. It worked once (kind of, i was able to get to the next page) but it kicked me back to the login page. Tried accessing with both a static and DHCP, router and direct connection. No idea on what to do. Please help
Unread 30-01-2010, 14:38
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Wireless bridge issues
By credentials I assume you mean the user name and password. What password are you using? Try admin admin.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 30-01-2010, 16:22
FRC #3332
Rookie Year: 2010
Yes. Once in a blue moon it lets me to the next page. But kicks me off after I click anything else.
Unread 30-01-2010, 18:01
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Is it a brand new bridge? We had one last year that was defective last year. It would act like it was working - you'd log on, change settings, etc. - but when you rebooted it, it would go off into nowhere and need to be reset to get back into it. It seemed like the memory that it flashed the settings into was bad.
Out of expediency, we bought a new one locally. I spent about four hours over two days on the phone with Linksys Tech Support going through their scripted troubleshooting procedures before they authorized a RMA. We eventually received a replacement which we kept as a spare.
It's possible it could be a defective unit.
Try a hard reset of the unit to default settings, (If I recall correctly, it involves holding in the reset button for 30 seconds.) then follow the bench test steps exactly. Pay particular attention to changing your computer's IP settings after the bridge is set to it's 10.xx.xx.x address and rebooted. If you forget to change the computer, you'll lose communication with the bridge.
But, it doesn't sound like you are even getting that far.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 30-01-2010, 22:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
When we set up our control system this year, I tried for nearly an hour to configure the WGA. It wouldn't accept the username and password. I finally got desperate and used Internet Explorer instead of Safari...and it worked.
Try using IE as the web browser if you're not already.
Unread 01-02-2010, 21:05
FRC #3332
Rookie Year: 2010
Problem fixed. I decided to screw the instructions and follow my way. What I did, if anyone is having similar issues:
1. Set up the router with a static IP (10.33.32.4 for me)
2. Wire the bridge to the router and the router to the pc.
3. Run the install CD for the bridge, do the one touch wifi link thing it tells you not to do in the directions... You should now have the bridge wirelessly connected to the router. Plug bridge into crio.
4. Change PC IP and all back to static and what not. And bam it should work.
wireless bridge problems tanguma26 Programming 8 31-01-2010 11:16
Wireless Bridge Problems furiousgeorge Control System 9 28-01-2010 13:28
Where to purchase Wireless bridge on Robot Yuan Xue Lim Kit & Additional Hardware 6 20-01-2010 15:00
Help connecting wireless bridge cactuarman Control System 4 24-03-2009 14:24
Source for Wireless Bridge Gary Bonner FRC Control System 1 07-01-2009 20:57
