Go to Post Aha I just noticed you're from my team. --Petey - Petey [more]
Unread 30-01-2010, 14:48
spooncwru spooncwru is offline
FRC #0126
spooncwru is an unknown quantity at this point
Solenoid not firing off Solenoid Breakout
We're can't get a signal out of the pneumatics bumper to fire a 12V SMC solenloid. The power is okay to the module, and I've tried two different modules on 12V and 24V power. We've tried the sample VIs in LabVIEW and building the code ourselves. Anyone else have this problem?
Thanks,
Team 126
Unread 30-01-2010, 17:25
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
Re: Solenoid not firing off Solenoid Breakout
We had this problem earlier today. It ended up that we had a faulty solenoid module on the c-rio, and a faulty SMC.
When you run your code to fire the solenoid (try to use their example because it WORKS), activate the solenoid with the LV control. When you activate it, there should be a little LED on the solenoid module on the C-RIO that turns on. (and off when you turn off the solenoid). If that doesn't fire, then you have a faulty solenoid module.
After that, we replaced our SMC with a fresco just for testing, and that did the trick.
Hopefully this will help!
||2009|| Entrepeneurship Award, QF - Traverse City | Rookie All Star, QF - Detroit | Highest Rookie Seed, Rookie All Star, QF - Michigan State Championship | Finalist - MARC ||2010|| Engineering Inspiration, Website Award, SF- Kettering | Judges Award, Website Award, SF - Detroit | Website Award, Winner, Michigan State Champ //Thank you 469 and 1918!! | Finalist - MARC ||2011|| Engineering Inspiration, Website - Kettering | Entrepreneurship, Website, Finalist - Waterford | Website - MSC
Unread 30-01-2010, 17:46
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Team Role: Mechanical
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Actually, we had a faulty solenoid breakout on the c-RIO and a faulty FRESCO solenoid. Also, check the polarity on the FRESCO. For some reason, ours was switched which made the LED on the SMC not go on. (On a side note, we also had a faulty digital sidecar and a faulty spike relay, all in the same day. It was not a good day for us.)
Feel free to email me or pm me with any questions.
Solenoid PWM? RedHeadRobotics Electrical 10 30-01-2010 21:01
Solenoid Not Working professorX Pneumatics 7 15-02-2009 23:20
Full solenoid controll off of one joystick button? m3rc1l3ss NI LabVIEW 2 11-02-2009 02:06
5 Amp Fuses for Analog Breakout & Solenoid Breakout finman Electrical 3 10-12-2008 11:59
Two Pneumatics off one Double-Solenoid Valve GrahamS314 Pneumatics 5 24-02-2003 23:49
