Go to Post Things go wrong; it happens to the best of us. You learn from it and move on. - Waynep [more]
Unread 30-01-2010, 15:53
Dryice101's Avatar
Dryice101 Dryice101 is offline
FRC #2130
Dryice101 is an unknown quantity at this point
Windriver Connection problems
We just recently started having some difficulties connection to the Crio through windriver whenever we try to connect we get that error message that shows up if you don't install the labview update. We did. We could really use some help. Thanks.
Losing your hope is as hoping to lose...
Unread 30-01-2010, 19:02
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
Re: Windriver Connection problems
okay we got it fixed we still would really apreciate an explanation as to why it happened so that it won't happen again. However if you are having similar problems you need to reinstall windriver then install the windriver update on the CD, then install the neccesary Labview update and then install the Workbenchupdate20100170.exe update.
yes lots of updates.
Windriver connection to cRio avolkov Programming 6 05-05-2009 08:40
bridge connection problems Bob Holmstrom Programming 9 21-03-2009 15:31
DS to Bridge connection problems CHSboy Control System 1 24-02-2009 14:07
Remote Connection from WindRiver Team1710 C/C++ 3 16-01-2009 09:41
WindRiver WPILib problems Dr Nick C/C++ 5 13-01-2009 16:17
