Go to Post ...and that is exactly why Dave is the coolest nerd I know. - Rich Kressly [more]
Unread 30-01-2010, 16:51
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
BDC-Comm Problems when setting jaguars up for CAN
We have been experiencing many issues attempting to use the BDC-Comm utility to set up our jaguars for use on a CAN network.
The getting started PDF for the jaguars state that before use on a CAN network the jaguars should be assigned unique IDs and have their firmware updated.
We've rebuilt the CAN terminator and serial to CAN connector and verified the pin outs and 100 ohm resistance with a multimeter, and attempted this procedure on multiple black jaguars.
BDC-Comm can "connect" to our jaguars when they are present. Whenever we attempt to assign a new board ID we get strange behavior that seems to change based on the ID selected.
This is the procedure we are using.
1. open BDC-comm
2. verify that we can disconnect and then reconnect to the jaguar (the jaguar's light continues to blink yellow even though bdc-comm states we are connected, although the light does go solid at other points, see the bold below...)
3. open the system tab
4. type in a new board id in the "New Board ID:" field
5. press the "Assign" button
6. Quickly stick a paperclip in the "user" button on the jaguar
We are getting different behavior based on the selected board ID
Here are the behaviors we have observed:
Selecting board ID 2:
Firmware version goes to "2"
Board information goes to "none, motor controller"
A "TEMP FAULT" appears
Selecting board ID 3:
Firmware version goes to "3"
Board information goes to "none, relay"
The yellow light on the jaguar goes solid as the assign counts down
A red fault condition appears with no text
Selecting board ID 8:
BDC-Comm crashes.
Since we've tried this on multiple jaguars with multiple "tested" cables, we are basically at a loss at this point.
Is anyone experiencing anything like this trying to use BDC-Comm?
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Where to find BDC-COMM utility? rrossbach Control System 5 31-07-2011 00:43
Trouble getting BDC-COMM to see the black Jaguar Randy Forgaard CAN 5 27-01-2010 09:14
Can ping CRIO and bridge, but DS shows no comm and no code Green2 FRC Control System 3 22-01-2010 23:55
Robot seems to be Disabled when using Jaguars Thxe C/C++ 2 11-02-2009 22:01
Camera power/comm problems disable the DSC rwood359 FRC Control System 2 03-02-2009 12:34
