Go to Post The "line" is the point at which we've raised the floor so high that the advanced teams are hitting the ceiling. The ceiling is pretty darned high (and the GDC keeps raising it), so I don't think we're in danger of that any time soon. - EricVanWyk [more]
Unread 30-01-2010, 18:43
chahalaman13 chahalaman13 is offline
FRC #3053
chahalaman13 is an unknown quantity at this point
LabView a specification needed..
hey ya all...
actually its my first year working in my school's robotics team and it's our school's second year.....
eventually all the last year programmers graduated and just i have a little question..
How do we store the project into the cRIO after we deploy it?(meaning when we reboot the cRIP the code is lost) i just need a little specification on how to make it stay in the robot or we have to deploy it everytime we reboot the cRIO...
thanx a lot for any help...
VB Stingers
Team#3053
Unread 30-01-2010, 19:06
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: LabView a specification needed..
On the Project Explorer window, away down at the very bottom of the file list, you'll see "Build Specifications" and under that the default name "FRC Robot Boot-up Deployment."
  • Right-click and select "Build"
  • Right-click and select "Run as startup"
At the end a popup will ask if you want to reboot your robot.
The program won't be active until you do so.
Unread 30-01-2010, 19:14
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
If you bring up the ProjectExplorer window, scroll to the bottom of the cRIO target, and expand the last item (Build Spec's). Right-click on the FRC Robot Boot-up Deployment. There are many options in there ... First you "Build" it. Then you "Set as Startup".
There's also some interesting information under the "Properties" option, but I don't fiddle with them, I just look at 'em ...
[edit] ... nice one Mark ... I should've hit refresh before I replied!
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Last edited by Ziaholic : 30-01-2010 at 19:16. Reason: ... second place by a few minutes ;)
Unread 30-01-2010, 20:50
DonRotolo's Avatar
Back to humble
FRC #0832
Hey, in my book you both get credit.
Not being a programmer, I went and tried to look that tidbit up...and failed.
Unread 30-01-2010, 20:55
FRC #3053
Smile Re: LabView a specification needed..
thanks a lot guys... i'll check it on monday.. nd thanks again... i really appreciate it..
Unread 30-01-2010, 20:56
Just Itinerant
Hey, how can any Mark(c) steer you wrong?
LabView Connectivity Issue - HELP NEEDED Neurovirus NI LabVIEW 1 10-02-2009 22:50
LabVIEW Filter help needed Ivan Helmrich NI LabVIEW 4 10-02-2009 13:37
Joystick Button Programming in Labview Help Needed domoarigato NI LabVIEW 11 28-01-2009 10:55
USB Specification (Don't hit me!) Total Meltdown Programming 8 07-03-2007 20:26
Specification for timing belt pulley on large CIM? Larry Barello Motors 10 15-01-2006 12:21
