Go to Post Q: "What does your robot do?" A: "It collects data about the surrounding environment, then discards it and drives into walls" - tsaksa [more]
Unread 30-01-2010, 20:43
rhf323's Avatar
rhf323 rhf323 is offline
El Capiton
AKA: Ryan Fuller
FRC #1458 (Red Tie Robotics)
Team Role: Leadership
rhf323 is an unknown quantity at this point
Solenoid Output in Dashboard
We copied the code from the Dashboard example and were able to get the pwms, analog sensors, and digital sensors to display on the dashboard.
How do we get the solenoids and everything else to work?
Unread 31-01-2010, 15:12
rdk1024 rdk1024 is offline
rdk1024 is an unknown quantity at this point
Re: Solenoid Output in Dashboard
rhf323: You mentioned that you copied code from the Dashboard example. Could you tell me where you found that example code? I am having trouble with the Dashboard on our Classmate PC and would like to see the example that you used to see if it might help me. Thanks in advance.
Unread 31-01-2010, 17:19
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Assuming you are using C++, I noticed that the dashboard example doesn't bother to check solenoids and instead just returns all off. Most likely because the writers didn't want to include the extra solenoid objects. If you add it yourself it probably will work
Unread 01-02-2010, 18:20
rhf323's Avatar
El Capiton
AKA: Ryan Fuller
One of the example projects built into WindRiver for us was a DashBoardDataExample project that had the code we used.
Unread 01-02-2010, 21:25
AKA: Ian Thompson
Rookie Year: 2010
yeah, that example doesn't do the solenoids. If you look at the code:
Code:
// Can't read solenoids without an instance of the object
dash.AddU8((char) 0);
that is what is sending the solenoid output. Almost all of the outputs in that example are really just hard-coded and don't actually pay attention to the real I/O. You will probably want to re-write that for the actual dashboard you use
Unread 02-02-2010, 15:12
rhf323's Avatar
El Capiton
AKA: Ryan Fuller
Well we got it working thanks any way
Unread 03-02-2010, 09:30
Kyledoo Kyledoo is offline
FRC #2603
Kyledoo is an unknown quantity at this point
How did you get it working? Are you using the default dashboard? Which values did you need to un-comment? Do you have to do anything like encoder1.Get() or does it just grab data from the inputs? This I/O stuff is so hard for me to understand!
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 30-01-2010 17:46
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
Weird Output from Dashboard Port Ian W. Programming 9 06-03-2004 21:33
Dashboard Output Question jnossen Technical Discussion 5 02-02-2002 19:52
