Go to Post I tell my friends that the robot is the kids product and the kids are the mentors product. - rwood359 [more]
Unread 31-01-2010, 09:19
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Motor to work like a servo...what's the best method?
When we push a joystick button we would like a motor to spin forward 90deg, reverse direction, and stop when it returns to home.
Currently we have limit switches to reverse the direction of the motor and indicated when it is back to home position, but with the code we wrote it only operates when the button is pushed. If we take our finger of the button the motor stops and does not return home. Should we set up a State Machine?
Can we use the limit switches on the Jaguars to make this happen?
Where do we get good basic information on CAN? CAN looks interesting but we don't understand what the advantages and uses of CAN are.
Unread 31-01-2010, 09:38
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Re: Motor to work like a servo...what's the best method?
That's the difference between a motor and a servo motor. A motor just rotates as long as power is applied. A Servo motor turns to a specific angle.
Currently we have limit switches to reverse the direction of the motor and indicated when it is back to home poisition, but with the code we wrote only operates when the button is pushed. If we take our finger of the button the motor stops and does not return home. Should we set up a State Machine?
That would be a good way to do it. Ben Zimmer has a good tutorial on that at his FRCMastery site.
You could. I believe that is allowed if you are using CAN. It's not allowed in the rules for PWM driven motor controllers.
One thing about limit switches in general, a switch is not a positive stop. I've replaced hundreds - if not thousands - of limit switches in industry because they were destroyed when a machine overtravelled. A switch can only tell a controller that something is at a position. If the processor gets hung up in a loop, or the motor coasts, something needs to stop the mechanical motion besides the switch until the processor catches up.
For that reason, always have a mechanical stop and always put the switch out of the path of the motion!
There were a couple good presentations on CAN bus but since my team is not using it, I don't have the links. You'll probably be able to find them with the search, though.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Best way for "servo" from motor & potentiometer? NinJA999 Java 4 18-01-2010 16:14
GOING TO THE ATL! Wait..... what's it like? asmo0901 General Forum 19 07-04-2009 16:23
Motor that acts like a servo thefro526 Programming 3 25-02-2007 18:02
What's your work-space look like =) [56K User warning?] Nhiem Chit-Chat 9 30-03-2005 01:26
What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. Robb Gerber Motors 2 23-01-2002 08:58
