Go to Post The less we talk about the game hints the faster they will come. - BrendanB [more]
Unread 31-01-2010, 15:48
blazingshadow blazingshadow is offline
FRC #1389
blazingshadow is an unknown quantity at this point
cRio problems
It started out with us not being able to download code to the cRio. It's now gotten to the point were we can't even see the cRio on the network in order to try to reimage it. The last log we have for it is
auto-booting...
boot device : tffs=0,0
unit number : 0
processor number : 0
host name : host
file name : /c/ni-rt/system/vxWorks
flags (f) : 0x8
Mounting tffs...
Attaching to TFFS... Datalight Reliance v3.00.1218T
VxWorks Edition for ppc603
Copyright (c) 2003-2007 Datalight, Inc.
done.
Cannot open "/c/ni-rt/system/vxWorks".
Error loading file: errno = 0xd40005.
Booting into Safe Mode from ROM...
Uncompressing kernel...
done.
2910608
Starting at 0x100000...
Mounting tffs...
Entering safe mode.
Initializing network...
Device 1 - MAC address: 00:80:2F:11:4E:8E - 10.13.89.2 (primary)
Device 2 - MAC address: 00:80:2F:11:4E:8F - 0.0.0.0 (secondary)
Unread 31-01-2010, 17:07
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Re: cRio problems
I would try communicating with the cRIO with a direct connect to the PC to eliminate any network issues. Do this with a different cable as well. Usually it is the simplest things that are overlooked that cause the majority of the problems.
Unread 31-01-2010, 17:18
ROFLcopter's Avatar
ROFLcopter ROFLcopter is offline
who was phone
AKA: Robert Grizzell
FRC #2364 (Oregon RoboHawks)
ROFLcopter is on a distinguished road
Send a message via AIM to ROFLcopter Send a message via MSN to ROFLcopter Send a message via Yahoo to ROFLcopter
Re: cRio problems
I also want to add when you do a direct connect use a CROSSOVER cable. They are almost exactly the same as an ethernet cable, but are usually colored Orange or Pink. If you still can't tell if a cable is crossover, look at the connectors on the end. The wires inside should be flip-flopped in color.
Example:
  • 1 2 3 4 5 6 7 8
  • 8 7 6 5 4 3 2 1
This signature has been removed in accordance with City Ordnance law L34.B3. If you feel this signature has been mistakenly removed for reasons not within the guidelines of L34.B3. Visit the City Courthouse #3 and file a report.
Problems flashing cRio? Caleigh C NI LabVIEW 3 30-01-2010 19:43
cRio Problems tanguma26 Inventor 3 25-01-2010 13:19
cRio problems tanguma26 Programming 4 21-01-2010 21:09
cRIO update 3.0 problems Two-Face Programming 3 14-02-2009 10:06
cRIO Problems computerboi1503 C/C++ 7 11-01-2009 09:35
