Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 31-01-2010, 15:56
L337Lobster L337Lobster is offline
L337 Programmer
AKA: Jackson
FRC #0225 (Awesome-O)
L337Lobster is an unknown quantity at this point
Exclamation Run code errors.
When i attempt to run the code to put it on the cRio i get the following:
Code:
init:
init:
No to.jar.file specified.
Using "suite\BuiltInDefaultCode_1.0.0.jar"
Deleting directory C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\build
Deleting directory C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite
Deleting directory C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\j2meclasses
clean:
Created dir: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\build
Compiling 1 source file to C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\build
compile:
Created dir: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\j2meclasses
preverify:
Created dir: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite
Building jar: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite\BuiltInDefaultCode_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
Romizer processed 73 classes and generated these files:
  C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.sym
  C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.suite
  C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.suite.metadata
  C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.suite.api
Expanding: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite\BuiltInDefaultCode_1.0.0.jar into C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite
Moving 1 file to C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\suite
Deleting: C:\Users\L337-Lobster\Documents\NetBeansProjects\MyRobot\image.suite.api
Connecting FTP @10.2.25.2
C:\Users\L337-Lobster\sunspotfrcsdk\build.xml:95: The following error occurred while executing this line:
C:\Users\L337-Lobster\sunspotfrcsdk\ant\upgrade.xml:40: java.net.ConnectException: Connection timed out: connect
BUILD FAILED (total time: 24 seconds)
I cannot figure out as of yet how to go about fixing this.
can't run code viper110110 Programming 3 18-09-2009 21:25
Errors compiling Kevin's new code (pragmas) Bryan Herbst Programming 11 31-01-2008 12:50
ADC code errors epl692 Programming 2 22-01-2008 12:56
Timers causing code errors? Uberbots Programming 6 22-01-2008 02:10
